pltIBuildPlotsCtrl GetLayerList
Gets the layer list of the model within the file.
pltIBuildPlotsCtrl_handle GetLayerList
HyperWorks Tcl Query
This command returns the layer list of the model within the file based on the set case, result type, request and component. If there are not layers when this particular case, result type, request, and component are set, nothing is returned.
hwi GetSessionHandle sess;
sess GetClientManagerHandle mgr plot;
mgr GetBuildPlotsCtrlHandle build;
build SelectDataFile "c:/demos/mv_hv_hg/HyperView Stuff/d3plotag" true;
build GetLayerList;
Success (the layer list [or nothing]) or an error message is returned.
Keywords
HyperWorks
Tcl
Build Plots
Query
